Can’t get any free chlorine reading
We’ve already had conversations
The biggest mistake people make is trying to argue with the pool. Do what it tells you. If you need a little more FC, add it. Don’t tell the pool that yesterday wasn’t so bad. The same goes with brushing/ vac-ing. My kids were my first line of defense for finding slippery spots (liner needs brushing). Cuz they somehow can touch every inch in 3 minutes flat.
Ewwwwwwe it’s gross over HERE !!!!
thanks sweetie I’ll get on that later. :)
Reactions: Jennybird
😂😂 sounds about right!
This is one happy doggie shark in a clear pool. Thanks all 💜
Where does everyone keep their muriatic acid? Right now I’m keeping it in the garage but the fumes are so bad when I open it I’m wondering if I should keep it a different place? I do wear a mask and all the appropriate protective equipment but I just wanted to get some input. I have a very very curious puppy so I have to be careful 🤪
Do not keep muriatic acid in an enclosed place, especially a garage. Any metal in the area will be corroded quite quickly.
Keep it outside. I use a 20 gallon rubbermaid trash can with lid. Others use a 5 gallon bucket with lid. Or a deck box, all plastic. Nothing else should be stored with it.
Do not use a mask when handling. Eye protection is necessary.
She actually doesn’t even need anyone else in the pool, she will swim around by herself, but sharks are very territorial 🦈😂
So I soaked the filter cartridge in cascade pods put it back in and the PSI is still 18 which is over 25% it’s baseline. How do I do with a TSP bath? Is it mixed with water? Overnight? What does it do different than the cascade pods do?
The DW detergent does the same thing that TSP does.
Only other step is an acid soak. Do the cartridges have indications of scale on them?
Jenny I did 50:1 MA in a landscaper tub for 24 hours each fall. I just walked a buddy through doing his a few weeks ago and his were spotless in 4 hours or so.
