Lol sorry there doesn’t look like much else to check. Unless there is a crack somewhere in that main drain before the pipe or a tear somewhere.
Yes, the hydrostatic plug probably should have looked at first especially if it wasn’t replaced after drain and refill.Do the main drains take a screw plug like the wall returns?
7 feet of head pressure is about 3 psi (I think you mentioned your pool is 7 ft deep at the main?). If you displace the water in the main with air and close the valve, should maintain some pressure in the pipe. If it’s actually zero, I think you found it.Just got the whole new valve setup installed. Skimmer holds pressure great. Returns hold pressure great. Main drain makes bubbles in the pool and the pressure stays at zero.
Its 8 feet at the main when full, but about 2.5-3 feet of water is out right now. However, I need to plug that drain line so I can get like 20-30 psi running into the line so I can listen for the leak. Results after work today!7 feet of head pressure is about 3 psi (I think you mentioned your pool is 7 ft deep at the main?). If you displace the water in the main with air and close the valve, should maintain some pressure in the pipe. If it’s actually zero, I think you found it.
Yes, there is a tool and it is expensive. I don’t see replacing it an easy job (with the pool full) unless you happen to be a diver and have dive equipment. Might make sense to get an estimate on replacement and make a decision from there.Post work update: pulled main drain cover, only took 3 dives! LOL
Hydrostatic valve is bad. Not taking dye that I could see but the o rings are swelled up and chunky in a BAD way. Like over 1/4" thick.
Is there a DIY tool for these things?
I also need to get a plug for the main drain, its not threaded.
I had a feeling about that thing.Is there a DIY tool for these things?
Amen to that brother! Fingers crossed all goes well. Have a great weekend.I don't pay others to fix what I can figure out myself.
