Where are you located? I can almost gurantee there is a lowes, HD, or walmart within a 100 miles that has pool chlorine
I'm in Central MS. I just checked and Home Depot close by does have HDX Chlorinating Liquid. I'll hit it this pm.
Thanks.
That is the issue. Nearly all household bleach now has additives Clorox has Cloromax. Many have Fabric Protection, scents, splashless, etc.Avoid bleach that states splashless, scented, or any type of fabric enhancers (i.e. polymers). These byproducts can cause cloudiness or foaming in a pool.
Several years ago you could buy Clorox bleach without additives so it was often recommended on this site, but then they made a change to their formula and Clorox bleach now all has "cloromax" which is a polymer additive that is not good for pool use, so it is no longer recommended.This is a surprising statement about Clorox to me since when I studied this several years ago on this site it seemed Clorox was the go to chlorinating agent. Here is a recommendation from Pool School:
"Household bleach and liquid pool chlorine are the two common sources. They are identical in every aspect except strength, household bleach is typically 6%. Pool chlorine typically sold at pool stores is usually around 12%. Avoid bleach that states splashless, scented, or any type of fabric enhancers (i.e. polymers). These byproducts can cause cloudiness or foaming in a pool. Basic, plain unscented, non-thickened bleach is ideal."
Have I missed something or thoughts on this changed?
Thanks for a reply.
MK
I'm in Central MS. I did find some HDX at Home Dpot.Where are you located? I can almost gurantee there is a lowes, HD, or walmart within a 100 miles that has pool chlorine
I meant if you CAN handle adding calcium. Cal Hypo adds calcium along with chlorine. What is your CH level of the pool water and your fill water.
Clorox bleach has Cloromax. A polymer. Plus it is just 6%. Very expensive versus Pool Essentials 10% from Walmart or HDX Chloronating Liquid 10% from Home Depot.
HDX 10% is in Pool Supply located in Garden Section.Is the HDX from Home Depot in the pool supplies or janitorial dept?
Also, is there a difference between the muriatic they sell in pool and concrete departments?
Thanks for the reply about the change in Clorox formulation. I had no idea. As stated above I found some Chlorinating Liquid which I will switch to.
I've attached a PIC of a box of this from HD ... How can I determine the "DATE" on the product ? or if THAT pic doesn't show it, WHERE can it be found? This is the only number I can find. Thanks
