18x36 in-ground, vinyl liner pool with one Aqua Genie skimmer/return, two return jets on steps, and Pentair pool sweep. Pool only leaks when pump is running, water loss is fairly significant 1-2 inches per day. I've had lines pressure tested and all gaskets/junctions dye tested, with no leaks detected with either.
I don't know where else to look and need some help. Are there any areas within the Aqua Genie that could be leaking, but still pass pressure test? Anything I could be missing?
Any help or suggestions appreciated.
