getreal720
In your original post, you stated that the original pump was only about 2/3 of the way full of water (not primed). You then went on to say the new one was a bit better. From the way you worded it, I concluded the original pump wasn't priming and it sounded like the new one may not be either. But if your replacement pump primes (no air in the basket attached to the pump) then your good to go.
It's nice to see you have a good source of liquid chlorine. By all means use that, if you have a source to get that stuff cheaper than bleach... that's what I'd be doing.
I'd also add on that there is no real reason to run your pump 24/7. If you have a variable speed pump you can kick it on to low for a lot of those hours but really running the pump that long is throwing money away on your electric bill. I personally have run mine as low as 4 hours per day and still have had perfectly clear water. If you haven't already, do the math and figure out how long you need to run your pump for a full turnover of the water. Mines close to (but a little over) 4 hours (probably more like 5 hours). I bought a timer so I don't have to mess with it. Running the pump and the filter "skim" your pool and circulate chemical. The chlorine is what keeps the pool clean and clear.
Still, some people feel good about running their pumps a long time. My parents run theirs upwards of 12 hours a day and sometimes as much as 24 hours a day during "peak" season. Their pool is no clearer than mine, but alas... not worth arguing over!
