- May 3, 2014
- 62,708
- Fiberglass
- Pentair Intellichlor IC-40
So the pool water had some CYA in it. From last year. So what you added this year added to what was in the pool.I don't know what that means. I lowered the water quite a bit last fall, but what's there now is also tap water and rain water.
If, after refilling this spring, the CYA was 20 ppm, which is not testable, then when you added 30 ppm worth you are now at 50ppm or so.
