My Intellichlor does not appear to be making chlorine. I have done all of the troubleshooting I can find and there are no obvious signs of any problem - power is fine, pump is fine, flow is same as always, salt level is appropriate (intellichlor & aquachek strip are the same level apart as they always are), all the lights are green, water temp is fine. I took it apart and checked for scale or any other internal problems or blade issues and found none. The unit is more than 5 years old (I don't know its actual age as we bought the house 5 years ago and it was already in place) and when I do the "life remaining" test all 5 lights come on; it is not unrealistic to think it is at end of life. Is it possible it thinks it is working and therefore not showing any red light indicators but it is not making chlorine? I would appreciate any opinions or info on similar experiences. Thanks. Update 8/19/20 - it appears it was indeed the test strips I was using. I switched to the TF100 test kit and confirmed there is chlorine. Thanks to all those who responded - I did learn a lot about the whole situation as pool ownership is still fairly new to me - looking for bubbles as an indicator, that my IC is too small and ended up with a solid, reliable test kit.
