The default amount of time for a pump to operate at priming speed is 3 minutes (on the Ecostar pump and also, I assume, in the Prologic). My Ecostar pump never needs more than a little over a minute to prime. I would like to reduce the prime time from the default 3 minutes to 2 minutes. I have gone into the menu on the Ecostar pump and reduced the prime time to 2 minutes. After making this change (and checking to make sure the change was made), the pump is still priming for 3 minutes. I am assuming that this is because it is being controlled by the Prologic. I have not been able to find any way to adjust the prime time on the Prologic. Is it possible to adjust the pump prime time on the Prologic?
Several years ago I did reduce the pump's maximum speed so that it does not prime at full speed. That adjustment required reprogramming the pump and the Prologic. That's why I figure the Prologic is controlling the priming time.
