So we've officially gotten to the point where it's to cold to swim anymore. This will be our second winter with the pool as it was finished right before winter last year. I didn't know what I was doing last year so I just left it how the builder set it up. Now that I have a little more knowledge, I think I want to configure my plumbing a little different for the winter and just want to make sure my thoughts are correct.
We have the typical pool with attached spa that spills over into the pool. Currently, in freeze protection, it cycles between pool and spa. I don't particularly want to do that as I've read about frozen valves so I want to set it up so that I have flow to both pool and spa all the time. I think I can cam my valves to the spa side just a little to get some flow to and from the spa when in pool mode. It will create a little bit of a spillover, but I don't think it will be near as much as when in full spillover mode.
I'm thinking to cam the spa suction to about 15% open and the spa return to about 20-25% open. My thought is that I don't want to pull more water from the spa than I return to it as that will just lead to draining it into the pool and ultimately draining the pool through the overflow as the spa drains down.
Am I correct in my thinking, or at least on the right path? Some suction from the spa and a little bit more return to the spa? Will that keep everything happy and allow me to just have the pool on freeze protection?
