Good day,
So I came back from the pool store (mainly just to verify the test results I’m finding with my taylor kit). They gave me this list of things to do before concentrating on what I went in for originally (which was to get my PH down).
1) Add 1L of phos defence (morning), wait 12 hours (no longer, no less)
2) Add 1 pouch zap oxidizer 600g directly into pool (night), Add 1 klear sok into pump basket
Wait 24 hours for water to clear up (water is quite clear now to be honest)
3) Vacuum pool
4) rinse cartridge very well (I’ve only had pool open for 2 weeks, do I really need to disassemble and rinse all the cartridges??? Was hoping to go 2 months before rinsing)
* re-test in 4-5 days and mention you were dealing with phosphates *
They said when I brought my water sample in that my FC was 0 (which I am going to verify tonight when I get home)
My original test results a few weeks ago were:
Salt 2900 ppm (just taken from prologic controller reading, not sure how accurate that is however)
Free Chlorine: 2.6 (13 drops x .2)
Combined Chlorine: 0 (never turned pink after adding 5 drops of R-0003)
PH: 8 (added 2 drops to get down to 7.6)
Alkalinity: 160 (16 drops)
Calcium hardness: 210 (15 drops it turned purple, another 6 tuned it blue)
Cyanuric Acid: I could always see the black dot, got a little cloudy at 30
Tested a few days ago:
Salt 3000
FC 3.6 (reduced my swg to 50% from 70% but now realize I was in the right ball park, the Hayward sticker said I should be between 1.0-3.0)
CC: 0 (maybe .5)
PH 8 (I’ve added a bunch of PH down from Walmart, hasn’t seemed to do anything yet hense my visit to the pool store)
Alkalinity: 180
Cyanuric Acid: 30-40 (used the sock in the skimmer, quite the difference from the first test results)
Now should I go ahead with what the pool store said or maybe try another product to get my PH down (hth ph down was being used)??? Pool store said the stuff at walmart, canadian tire ect has more "fillers" in it (they sell ICP branded stuff). I also plan on adding some more Cyanuric Acid.
3) Vacuum pool
Salt 3000
CC: 0 (maybe .5)
Alkalinity: 180
