- Mar 17, 2019
- 612
- Plaster
- CircuPool RJ-45 Plus
Hi,
I needed to lower the level of my pool water about 5" for a concrete decking repair starting tomorrow.
When I did I realized I had a white ring which I presume to be calcium around the circumference of the pool. See attached pic. The ring is on the PebbleTec surface; I have no tile.
I'm almost certain it's scale buildup from years of not managing pool chemistry in the best way. Currently my CH is 550 (prior to the partial drain), and my pH is 7.6.
I do not believe a pumice stone will remove the line but I can certainly try if you folks think it will. Wondering if I should just bite the bullet and have it professionally removed, since the pool is partially drained already? Is it an acid wash that I should look for?
Thanks.
Thanks.
