First, turn off your SWG until 24 hours after adding salt.
How confident are you on your pool volume? Did you use the water meter to calculate when you first filled the pool?
Start adding CYA using the sock method. Target 60 ppm for now, test and confirm results.
You'll need to add liquid chlorine until salt dissolves and you get your SWG running. Add enough to raise your FC to 5 ppm. Maintain that level until you get your SWG running. You can use tablets to maintain 5 ppm since you need to increase CYA anyways.
If your showing no salt now, add enough to get you to minimum level as recommended by your SWG manufacturer. Use Pool Math to estimate the amount of salt. Test 24 hours after adding to confirm results. When salt is in range, turn on your SWG.
I pour the salt on my sunshelf with the pump running and agitate with the pool brush until it dissolves. "Pool salt" dissolves faster because it's made up of smaller crystals, but it costs more than regular water softener salt. Any plain water softener salt will work. I use
Diamond Crystal Solar Natural water softener salt. It dissolves quickly and is cheap.
pH looks good for now. Don't worry about TA for now. It will come down as you add MA to control pH.
Your CH is where we would expect assuming you did a complete drain/refill.
