Hello,
I have been using TFP and TF Test Kits for three seasons. This is our fourth year with a pool and my fourth year using the TFP Process for balancing our water. I am in the midst of SLAMming since opening the pool last Saturday, May 16th. Here are my current levels:
FC: 13
CC: 0
TC: 13
CH: 50
TA: 100
pH: 7.7 (may not be accurate since I've been SLAMming)
CYA: 50
I just added liquid chlorine to bring the FC level up to the recommended SLAM shock level of 20 for a pool with a CYA reading of 50.
My question is on calcium hardness and total alkalinity. We have a vinyl in-ground pool. Do I need to get my calcium hardness up higher? I see the recommended levels for my type of pool are 50-550. Also, does my total alkalinity need to come down closer to 80? My TF Test Kit instructions say I should be around 100 but the TFP recommended levels page says 60-80 is ideal and 80-90 is an acceptable maximum level.
Any input would be appreciated. Thank you.
FC: 13
CC: 0
TC: 13
CH: 50
TA: 100
CYA: 50
