I've been using cal hypo for years. My calcium levels are now starting to get higher than I like, am I able to make a clean swap to liquid bleach or do I have to wait to cal hypo is burned up?
Thanks
Thanks
When you add CalHypo, the calcium stays in the water until either splashed out or removed, while the chlorine is used up quickly.
Make sure to maintain FC levels using levels per FC/CYA Levels as tested from a proper test kit. Test Kits Compared
