Buying refills for test kit
I have the Taylor 2006 test kit already.
Is it okay to buy the TFT refill set and use with the comparator tubes if the Taylor test kit? The chemicals seem to be identical.
Or should I just buy the TFT full set with comparators?
TIA!
Same reagents. You can get the K-2006 Refill Set at TFTestKits. They wont fit the your Taylor box unless you carefully transfer the contents (a minor inconvenience).
Reactions: whitbyPool
The pH reagent is different for the K2006 versus TF100. TFTestkits has sold K2006C refill sets. See if they still have that.
