Hi all, we are building a vinyl pool and the installer is offering a built-in Polaris robot for $2500. Is that something we should consider as opposed to purchasing a separate electric robot afterwards?
If I were building a pool I would want to get this. But it is still only in beta.
Otherwise listen to Allen.
They are, almost everybody's robot around here is a Maytronics. They are pretty much the pool robot leader.
Just ask your pool builder if he is planing on a pressure robot, if so turn it down and get a real robot. If you cannot get into the beta (I think it will be hard). Then plan on designing a good storage spot for a Maytronics robot and make sure you get a good GFI outlet installed close by to power.
Get think it through and do a nice design. It was one of the mistakes I made when I re did my pool.
So if you dont get on the beta, another option would also be to have your pool builder add another conduit that terminates around the spot you would want to put the poolside connect.
When you get through to Maytronics see if they can at least give you the specs on what they need. Pre build for it, and then you can always add it later when it ships.
