New to TFP, a lot of really good info on here. Currently building a pool in Cypress Texas., ~12,500gal, + ~500+gal spa. Chlorine. definitely want to follow TFP and use liquid chlorine; wanting to install Stenner pump and tank, a few questions.
1. Anyone ever had a pool builder install this for them? I am still pretty early on., plumbing and electrical have not started yet, thinking if I buy this I could have electrician/plumber set it up.
2. Was looking at 7.5gal tank combo 3gpd fixed rate 25psig stenner pump. Anyone see any reason that set up would not work well for ~13000gal pool based on my preliminary look I would say I would maybe use around 30-40oz of 8.25% per day. Pump would run maybe 2 to 2.5hours a day for those rates which I am good with. see no reason the 25psig would not work as pool return pressure should be well below this correct? see some use the 100psi model curious why.
3. Does most pool electrical run 240v or 120v? would the 120v stenner be ok, if i want to wire into pentair intellicenter relay for control etc. obviously this is where i would have electrician set this up for me, just not sure if it would have to be a 120 or 240 at this point.
4. Assume if i had the plumber add a 1/4" female threaded connection in the return that would be all i need from them and very easy for them to do this if i tell them.
thanks to all with any info or additional info you can provide.
