- Sep 21, 2007
- 121
- Vinyl
- Hayward Aqua Rite (T-15)
I have always sanitized my hot tub using the 3-step system described in
How do I use Bromine in my spa (or pool)?
I used liquid 'Rendezvous Enhance' (35% Sodium Bromide)
The instructions were clear that the initial dose was @ 125ml/1000l water.
I rarely used the weekly dose of 30ml/1000l and I maintained bromine tablets in the feeder, and after each use I used 'Rendevous Activator' (potassium monopersulfate, MPS).
My pool store is no longer able to get the Rendezvous Enhance/Activator.
They recommended 'Spalife EZ Brom' (15% Sodium Bromide granules) and 'Spalife Shock' (Chlorine Free Oxidzer granules, contains MPS)
I just changed the water and I am trying to determine how much EZ Brom I need to build my bromine bank.
The instructions state 6g, (1/2 tbsp 7.5ml) per 1000l water repeated until residual of 3 to 5 ppm.
and superchlorinate at 25g (2 tbsp, 30ml) per 1000l water as required.
I'm questioning the dosages because the 35% Enhance required 125ml/1000ml, I'd expect the 15% EZ Brom to be close to 300ml/1000ml.
Which would require 20 repeats of 7.5ml.
Is the difference explainable if the liquid Enhance % could be %volume, and EZ Brom granules %weight, or am I missing something?
I thought the Rendezvous product might be discontinued because of Canadian restrictions on the use Sodium Bromide with MPS.
However these products continue to use Sodium Bromide and MPS activator.
