- May 23, 2015
- 25,699
- Plaster
- Pentair Intellichlor IC-60
The best advice always is to have a good test kit and make sure that you are dosing your tub so that your tub always has 4-6ppm Br. That’s what’s going to give you the usage data you need to see how much of the chemical you’ll be using. At first I would expect to dose a lot as it takes time for the bromide to build up. Careful records are the best.
Happy tubing and feel free to post any usage info you obtain on the new product. I’m sure other Canadians will benefit.
