Wireform: Thank you for taking the time to provide a thorough explanation. Let me make sure that I understand you correctly. In my situation, the rope broke on the motor-side of the cover when the cover was open. As you said, with the cover open there was relatively little rope on the spool. Are you suggesting that I cut back the remaining broken rope on the spool? If that is correct, I am curious as to why cutting back the remaining broken rope will make any difference? The rest of your explanation seems straight-forward.
BTW, I had planned to replace the rope myself. But after a bit of inspection & head scratching, I opted to have a CoverPools dealer do the work. The job wasn't rocket science, but not having done it before it would have been a bit daunting for me.
Again, thank you for your help!!
