I've got an Intex above ground pool with sand filter and salt water generator. The pump motor has died and Intex says the part is on "back order" and likely won't be available this summer. Unless I buy a whole new pool, the filter/SWG that works with my pool is unavailable for purchase online or elsewhere.
If I manually dump chlorine into the pool daily and keep all the other chemical levels in line with the TFP guidelines, how long can I safely use the pool without a pump?
