Hi,
I opened my pool this year after winter (my 6th year doing this) and the pressure gauge on the sand filter seems abnormally low. Usually, at normal operation it is at 12-14 psi....its reading at about 4-6 psi. However, there is plenty of pressure at the jets and water seems to be cycling through the system with no problem. Although I did have a little trouble this year getting the pump to prime, seemed like there as an airlock in the line, so I added water to that line to get the pool to prime. Running fine now.
So, I am thinking the gauge is broken since I do have lots of pressure at the jets, but the needle does move back to 0 when the pool is off, which is why I'm not sure.
