so we were enjoying swimming in our crystal clear TFP pool, when my daughter notices that there's a foreign object at the bottom of the pool
turns out, the pool light cover has broken somehow (see pic) and it was a piece of glass in the pool
the light never worked since we moved in, i'm not even sure where the switch to turn it on is!
now, from what i have read, i should:
1) turn off the power at the breaker (i think i might just turn off every switch in my fuse box)
2) undo that phillips head screw
3) remove the light section which should have enough cable to reach outside the pool
my plan was to just buy the exact same light and swap the covers, i don't really care if the light actually works or not, i've never used the pool at night
i just don't want more pieces of glass to dislodge and fall into the pool
anything i've missed, or other recommendations?
cheers
cheers
