Probably something like 1.5" MPT to hose barb adapter ... 1poolman1 might have a better idea of the common name.Do you know what that part would be called?
Is that outlet just the drain on the bottom of the filter or the feed that is supposed to go back to the pool? If the latter, then the advice to plug it in the post above is not going to be helpful.
