Hi All,
Yet another “I’m in Texas and didn’t make it quite through the storm” posting. As you can see from the picture, my booster/cleaner pump didn’t make it. I feel like there are others in a similar situation. Based solely on the picture, I’ll ask the unfair question...”is the entire $400 pump needing to be replaced?” I suppose that’s not horrible given other potential things that could have occurred. In any event, did I read elsewhere that another suggestion is to remove the pump altogether, and go with a robot? Would I then just connect the two pipes to keep circulation going? I like the convenience of the Polaris, but if I’m going to spend $400 + labor (assuming I’ve got the pump cost correct), maybe the robot route is worth it?
Polaris PB4SQ is the pump model.
Thanks for the assistance,
Jim
Jim
