Breaker Size for Superflo VS
MikeSaw75
47
Illinois
So I'm planning on running the electrical and gas for my pool next weekend and have a question. I am getting the Pentair Superflo VS and running it on 120v but cannot for the life of me find out the circuit breaker size. I know it is rated at 13.2 amps max and wanted to put in a 20amp GFCI breaker. Would this be okay?
Code is requiring me to use a twist lock connection on the pump itself. I plan on using a L5-30 power cord which is 30 amp. Overkill? I cannot find any 20 amp twist lock options.
mas985
13,733
Pleasanton, CA
Normally, you want to have an operating current less than 80% of the breaker rating. So in this case, you can use a 20 amp breaker or a 30 amp is ok too. However, you need to make sure the wiring to the outlet (not just the power cord) can handle 30 amp as well.
Reactions: MikeSaw75
MikeSaw75
47
Illinois
So I'm going to install a standard 20 amp breaker in my service panel and then go into a faceless GFCI all inside the house. From there I'm going to run it outside into a Hubbell HBLPKL520 Pool Pump Kit. This kit comes with a 20 amp switch and twist lock receptacle along with a waterproof box and cover. I was able to find an L5-20 power cord also to wire into the pump.
I'm going to run a separate circuit using another faceless GFCI to two duplex outlets so I can plug in my heater and a SWG when I choose to get one.
Now time to dig the hole to set the 6x6 post so I can attach the electrical boxes.
MikeSaw75
47
Illinois
I plan on adding a timer for sure when I get the SWG. I figured I can wire this in at the same I install the SWG and will give me some time to figure what timer to go with.
