Hello everyone,
We bought a new P-R406A-EP-C propane pool heater to replace the old one which failed after 15y....Installed in the same location/connection etc, called the gas company, they reconnected the propane/check pressure but it wont lit. This is basically what happens:
-Pumps are ON and water flowing
-Propane is turned on
-Gas valve is switched to ON.
-Power is ON, pool selected
-Set the temp above current displayed
-We hear the spark for 90sec or so, and then it goes in ignition lockout.
What can be the cause, this is the digital model with honeywell gas valve, not sure where to check the pilot etc...
This is a brand new model replacing the exact same model.
Please help.
Thanks!
Please help.
Thanks!
