I bought a replacement for a broken H500 in the Fall and just installed it today.
The system fails with an A0
I've read that A0 means the vacuum sensor is not reading a vacuum -- either the fan motor is not creating the vacuum or the sensor is no good.
The fan is spinning nicely, and the unit is brand new. Totally clean inside, vacuum and pressure hoses nicely pushed on to both the fan housing and the sensors.
It's been too long to go back to the vendor.
I was hoping that because the propane gas pipe sat turned off all Winter, maybe it just needed time, but it's been a couple of hours of trying to make this work.
What should I do?
Thank you!
What should I do?
Thank you!
