It’s GFI. I have the swg and the pump plugged to a timer. I’ve tried removing the timer, but it still shuts off.
May not be a bad idea to have a electrician or someone who has done a lot of wiring to double check it.It’s GFI. I have the swg and the pump plugged to a timer. I’ve tried removing the timer, but it still shuts off.
Also, my RJ60 says my salt is at a very different level than the test kit. You might check what the generator is seeing vs your test kit.
I started with my salt at 3500 which is where I kept it for my intex. When this swg didn’t work I raised it, then we had several days of rain and lots of overflow, when I rechecked it it was 3200, so I brought it back to 3600, then Saturday Discount Salt Pools said to raise it to 4000 and try again.You said you raised your salt level to 4000 on the very first post, did you raise it more?
3600 to 3800 is perfect for these..
Ah, but I wonder if it can detect under/over salt levels and disable itself when it’s out of range? If my test kit shows 3600ppm and the display reads 4000+, then the OP levels could be close to 5000ppm if circupool uses similar sensing controls?The SJ does not have a display![]()
DSP had me adjust a screw that controls the sensitivity of the salt sensor,.. still runs for less than a minute, then the red cell light and red salt light come on and it stops generating. I have removed the timer, the pump and swg are now on their own circuit. Still not workingAh, but I wonder if it can detect under/over salt levels and disable itself when it’s out of range? If my test kit shows 3600ppm and the display reads 4000+, then the OP levels could be close to 5000ppm if circupool uses similar sensing controls?
I turned the hose on full blast, let the pump run for a few minutes,.. should have gotten a low salt?? It ran for a minute just like before and both the cell and salt light came on red, and it stopped generatingcan you try a test for me... Put a hose into the skimmer and turn it on full blast and start everything up... see if that does anything...
DPS has shipped a new cell today. They think it is a faulty sensor in the cell.well that sucks, I was hoping it would stay green.... I am lost now... did you try turning the hose down half way.. just trying to figure out if the salt is too high or low as The only reason it stops is the salt is low or high..
What is DSP saying?
