Leak detection guy came today and here are the results…
1. Large leak in the light niche cover ring. I’m not sure exactly how that could leak but he said when he put his acoustic “dome” over it…”it was screamin’ at me” which is a technical term for it leaking a lot.
2. No other leaks found, even in my deep end skimmer. He did say he noticed the weir door was a little sticky and that might be preventing enough water from getting in and causing my suction leak.
After doing a test for #2, it seemed he was right. Once I opened that valve, the skimmer slowly emptied of water until air was getting in. So I removed the weir door and did a little sanding on one edge that was hanging up on the side of the skimmer body. And it’s now working. I’m going to watch it for a couple days just to confirm the leak is fixed.
Here’s my pump basket with all three suction lines open. Only a few small bubbles!
And now for the damage report, cause you can’t have 3465+ gallons of water leak underground and not have any damage. Crack in the deck near a joint at the back of the deck slab near my pool light.
And since the back sunk a bit, it lifted up the coping side a bit. You can see the horizontal crack that split at the majority of the slab lifted but left a small portion glued down to the tile. I’m convinced that the expansion joint they cut above the tile was obviously not deep enough and so the new cement that was added, bonded to the pool shell better than the deck slab. This is evidently why expansion joints are so important! Oh well, if that’s the worst of it, I can deal with it later once the ground dries out and I’m convinced it’s not going to move anymore.
