Thanks for all the help and suggestions. I used the the litmus type test strips that came with the generator, it showed not a drop of salt. Looked to buy the salt test kilt k-1776, here on the site but only found it to be confusing and no actual kit to buy, it made mention of refill stuff for the salt kit. found it on Amazon, and ordered it there. i can't understand, a problem or maybe just a circumstance that I found this beginning opening. Last year i drained the pool to six inches below circular return orifice. when I took the cover off it was 8 inches below that. other years this was never the case. The only difference this year, was that I used a different type cover. The expensive kind that you put down with heavy springs that you bolt to deck and stretch the Crud out of. The water goes right through ie the cover. I thought that when I took the cover off this year I would have more water, because in the past my covers would keep rain water and snow melt out. Did this type black cover just allow all the water to evaporate out through the cover? I have had to put half the pools water capacity back in the pool. 100 bucks shot all to heck. Now that the water is almost back to capacity, I don’t know how to proceed. I have plumbed in the generator but not the electric yet. I am wondering if I could run the pool like before the generator installment, without plugging in the generator in. To circulate the water that I am trying to clear up, it was green, I put chlorine in, and now the water is just cloudy. Will this hurt the generator running water through it without the electric attached.
