- Dec 28, 2022
- 48
- Plaster
- Pentair Intellichlor IC-60
Hopefully a quick question. Our tapwater here has a high pH and high alkalinity so I frequently add MA up to a couple of gallons a month I’m considering putting borates in the pool using boric acid. I’m not sure how the chemistry works but when I go to Pool Math to lower ph and input 50 ppm borates I noticed that the use of MA goes up dramatically. I think I read somewhere that boric acid will help buffer the pH, but I don’t want to stick something into the pool that increases my MA use more than five times when I need to lower the pH. maybe I don’t understand how the two acids work together with the pH because it seems that a lot of people like borates in their pools.
