Booster Pump not starting or making any noise
adamfrey
16
atlanta
Hello super helpful forum members.
Just opened things up and started the Cleaner and the booster pump doesn't start up at all. It was working back in the fall. Reset the breaker and no leaks but wanted to check with you all first for any suggestions. I will be looking up the robot models.
ajw22
21,269
Northern NJ
Pentair Intellichlor IC-60
Check that the pump has voltage at its connections.
Check the start capacitor in the hump.
Get a robot cleaner.
RDspaguy
In The Industry
Mar 21, 2020
1,011
Cabool, Mo
Also, with the power off, try to turn the motor shaft by hand with pliers between the motor and plastic wet-end, or from the back of the motor under the cap with a screwdriver or allen wrench. The bearings might be sticking.
mknauss
33,937
Laughlin, NV
We are glad you have found our information helpful. Please, if you can, consider making a donation to TFP.
We are staffed by volunteers and are registered as an IRS 501 (c) (3) charity and donations are what keeps the forum operating without advertisements.
Support TFP!
