I recently got a house with a pool. I've gotten the chemicals down. Everything is fine on that end. I've noticed that the Hayward booster pump 5060 is 20 years old(?) and has a leak. Is the booster even worth getting serviced? This pool vacuum is strong, but it does get stuck and tangled all the time.
If I were to stop using the pump and switch to a robot vacuum or something, would you recommend redoing the piping completely? Or would it be fine to just remove the booster pump and just connect the pipes together? I will be doing my research but I thought I'd ask for some opinions on this as well. What would you all do if you were in my situation?
