Bonding issue
ajw22
11,246
Northern NJ
Basically a high voltage ohm meter.
It could be used to test for leakage from the motor windings to ground, usually at a few thousand volts.
Yeah, that is why i said earlier in the thread that replacing the motor will probably fix the tingle. I don’t know if the average electrician would have a megger.
cj133
217
NJ
That 2.5 volts neutral to ground is your tingle. You should not have current leakage to ground.
I'm going to respectfully disagree.
My opinion is that 2.5 volts is the voltage drop across the neutral and is expected with a load on the circuit. It doesn't mean there's any leakage.
cj133
217
NJ
When I google “neutral to ground leakage” most pages say under 2 is normal. Some say 3v.
Regardless, I ordered a pump last night.
The thing is, you're going to see the same thing with the new pump.
Honestly, you should have an electrician come in.
doc8404
452
Rome, NY
May do that if new pump doesn’t fix it.
What else could it be?
Thing is, 1-2 years ago due to seal leak And corrosion I considered a new pump.
Electricity is 10.9 cents/kWh here.
Both good reasons to snag the dual speed I found on sale (same pump I posted but different source).
cj133
217
NJ
appreciate the reply.
Why do you think i'm going to feel a tingle with the new pump?
I honestly don't know that you're feeling a tingle with the old pump. Perhaps it was the angle you had your finger at vs the water flow.
What I'm saying is you're still going to see the 2.5V+- difference between neutral and ground with the pump running.
That's why I'm saying if you have a concern, you should have it checked out.
Reactions: doc8404
doc8404
452
Rome, NY
Thanks. I sent the electrician a message.
Something is giving me a tingle.
As I stated earlier,
Finger in skimmer it tingles.
Wife shuts off pump using switch on pump, tingle stops.
