Bond. (Not James) Bond.
synapsid
70
Long Island, NY
Hi there,
When my AGP was installed, we did the bonding to code with the assumption that we would use the PVC ladder that came with our pool. Since then we built a little deck and got an over-the-side ladder that has stainless steel uprights and PVC steps.
I assume I must now include this in the bonding loop, is there a simple way to do this?
Thanks!
Depends how easy it is to run a wire from the metal uprights to the bonding wire.
I would not worry about it if the ladder sits on a wood deck and in the pool water.
Reactions: synapsid
Thanks. The deck is composite timbertech and the ladder’s in the water. I could connect both uprights to the loop but I would have to disconnect whenever I remove the ladder.
Not knowing how you have the ladder anchored to your deck, I am guessing that the points that hold the ladder are also metal and connected to the rails? If so, you could possibly use a stud where the underside is longer and held in place with nuts and then you could connect to that using a lug. This way all you need to do is loosen the upper nuts leaving the studs and bonding connection in place.
This is the general idea...
Reactions: synapsid
Yes! Thanks - the ladder is held in two metal cups. I had thought about trying to connect to that. As a bonus, the wire would then be completely hidden under the steps of the deck.
