Thinking ahead about my first closing(maybe too much ) and I am wondering about my spa drain. My plan is to clear out and plug all suction lines and returns with the air cyclone into one skimmer, leaving the main drain and spa drain for last. With those lines clear, my MPV set to closed, and my spa drain diverter set to 45 degrees will the air cyclone be able to blow out the spa drain? That is will the air pressure sort of "go around the corner" formed by that 45 degree opening and not be affected by the check valve? Probably over thinking this but would appreciate any reassurance that it should work fine.
