Blocked pipe
markayash
3,525
Atlanta Ga
That’s crazy, I vision some guy saying “ I can’t push the pvc in any further” as the guy with the backhoe says “ hold my beer watch this”
Reactions: Caliguian
drsipe
167
Middletown, Pennsylvania
CircuPool RJ-60 Plus
I was planning to just fill it back in with the same dirt/sand that I had pulled out of it.
I don't have a lot of experience with household/pool pipe backfilling, but I worked in a power plant for over 30 years and we had a lot of buried piping. this may be overkill, but we always filled from 2 inches below the piping to 2 inches above the pipe with sand. We found that backfilling with natives soil, gravel or stone led to additional leaks. When there is flow thru the pipe, you get some vibration, eventually a stone against the pipe wears thru the pipe and you have a leak.
When my pool was installed , I insisted of packing the pipes in sand. Again, that may be overkill but it's cheap insurance.
Reactions: markayash
markayash
3,525
Atlanta Ga
When I replaced a piece of pvc for my main water feed I sprayed it with that flex Rubber spray stuff to help protect it.
phonedave
991
Montville NJ
Hayward Turbo Cell (T-CELL-5)
I used to be a geotechnical field engineer. Anything I inspected - water mains, gas mains, storm drains, storm water detention systems, road culverts, etc was bedded in sand, for just the reason you describe.
Pool piping may be overkill, but it's not going to hurt either.
