Looks like black algae. Break a 3" tablet into a shape that will get into that corner, wet the area and scrub with the tablet. Should remove it. A paste of cal hypo will do the same.Hello everyone, so I was looking at my pools skimmer and I noticed this black foam /hard material that seems to flake. I don’t know what it’s called. Is it replaceable so it doesn’t throw flakes ? Attached will be an image
Black algae ? Black algae can form into a hard material ? I will attempt to scrub it and see if it will go away. Besides scrubbing it, will I need to do anything after ?Looks like black algae. Break a 3" tablet into a shape that will get into that corner, wet the area and scrub with the tablet. Should remove it. A paste of cal hypo will do the same.
Maintain proper chemical levels. Since that area of the skimmer is not usually in contact with the water continuously, you may have to just repeat the process from time-to-time.Black algae ? Black algae can form into a hard material ? I will attempt to scrub it and see if it will go away. Besides scrubbing it, will I need to do anything after ?
Quick question, when you mean tablet you’re referring to a chorine tablet correct??Maintain proper chemical levels. Since that area of the skimmer is not usually in contact with the water continuously, you may have to just repeat the process from time-to-time.
Don't use a tablet.Quick question, when you mean tablet you’re referring to a chorine tablet correct??
Yes.Quick question, when you mean tablet you’re referring to a chorine tablet correct??
A magnet did not stick to the surface. Could it be another material ???Don't use a tablet.
The black is a spanner for the skimmer to hold the bricks up while they are being placed.
