- May 3, 2014
- 62,694
- Fiberglass
- Pentair Intellichlor IC-40
I typically use a 5lb bag of each (ph down/pH up) in a season. I try to keep my CYA high to keep the pH balanced.Likely copper or a mixture of copper and silver. But they have to come from somewhere.
How much pH down (dry acid) do you use in a typical swim season? How do you add it?
Realize Pentair specifically states in the SWCG owners manual to not use dry acid.
great. How do you add it to the pool?I typically use a 5lb bag of each (ph down/pH up) in a season.
Was it a blue liquid?No algaecides except back in April when I opened the pool up.
Copper.What metal will leave a solid black residue?
Are there filters that can be put inline that will catch the copper from the water as it filters the water?Once you lift the stains, the water must be removed from the pool as the copper is now in the water.
You can do a no drain exchange, it should get most of the metals out if you do 1.5 times pool volume or so.
It is just for a test and not for whole pool treatment.Any suggestions on where to purchase some 100 percent aluminum sulfate?
no.Are there filters that can be put inline that will catch the copper from the water as it filters the water?
