Black Algae...no cya...and a pool that eats chlorine for lunch...
rn22lr
6
I know I have had a black algae problem for several years. Grown kids, an increasingly busy career......blah blah blah blah. So here I am trying to get the pool out of the clear but clearly having algae in every crevice.
Pool is a generous 15k gallons, probably plaster (best guess), SWG, DE filter. Nothing is automated, except the timer starting the pool pump. You want to change how much flow or intake.......walk over to the pool mechanics and start adjusting them.
Spent the last week adding liquid chlorine and brushing with some success but my low cya levels (dip stick shows none, pool store shows 40), many hours of direct sunlight and the algae has me zipping through the chlorine. Right before I started, I bumped the DE filter and adjusted the pH to 7.2.
Since last Saturday, I have brushed every day and went through 14 gallons of 10% bleach and 2 gallons of 6% bleach.
I added two more gallons of chlorine this morning waited 30 minutes then started the sock method adding 4lbs of cya. Frequent squeezing and attention..... the cya seems to be nearly dissolved.
When can I add more liquid chlorine/bleach safely?
rn22lr
6
Unfortunately..... I am using the pool store and dip kits. Let's just say.....after being married 28 years I know it isn't worth the argument with my husband.
Hopefully, you all can help me despite that handicap. Because it isn't getting fixed.... unless I hid a test kit :)
rn22lr
6
Sigh. I wondered if the test kit would be a deal breaker when it came to getting help.
It is what it is....
kimkats
44,703
Tallahassee, FL
Go to Walmart and get one of the "baby" HTH 6 way test kits. That at least will have you the REAL value for the CYA at least they you can know what FC to shoot for.
PoolGate
4,483
Damascus, MD
You are fighting a war but only fighting it defensively. Instead of using short range artillery, keeping your enemy at bay albeit without advancing, you need to go for the win. Fall back to orbit and nuke the entire site for morbid. In other words, you need more chlorine!
Reactions: Flying Tivo
