onBalance said:
I agree and prefer lighter colors (as opposed to very dark colors) and think they look really good. I think you will be pleased once the pool is full and the water is filtered and sanitized.
Choosing the pool finish color was a heartache for me. I selected a few and when the plasterer showed me those in a pool, I hated them. I hated the texture of the small pebble finish, I hated how dark the colors were in person. I think that due to the depth of my deep end and my ability to circulate water from the deep end over the huge waterfall I could have moderated the overheating of the pool in the summer and probably bought a few weeks of additional swimming time. But, the whole issue of loss of pigment to the harsh TX sun, the effect of the massive pollen load that hits my pool from pines followed by oaks, the risk of hydration problems due to TX plasterers using more water than you might want while troweling..... so many risks.
I noted that in the pools of a few "experts" they had white plaster with colored quartz. I tried to find a mix of barely tinted plaster that would not be too affected by pollen, but not be so different from the quartz color so that exposure problems would not be so visible. Plus I wanted to tend toward grey without using grey plaster. So, I was spinning back and forth between Smoke and Jade. Smoke was just SO dark in the pool, and pollen was reported to be a big deal by L Katona in Houston on GardenWeb. There were 3 or 4 very similar Sunstone Quartz colors that would have been fine but I wanted turquoise not so much a true blue. In blue, they had Blue, Super Blue, and Blue Quartz with varying amounts of white to grey. My Jade is most like Blue in that it has a barely tinted plaster with grey and black and turquoise instead of blue added. Cayman would have been a lighter version of that on the turquoise side where Blue Quartz was similar on the blue side.
I was still flip flopping from Cayman to Jade to Smoke 12 hours before they started. My husband was ready to have me committed. "Not that much difference between them!" Finally I flipped a coin and called the plasterer to change to Smoke. He talked me out of it based on pigment durability and, more importantly, that I'd have to wait a week to be rescheduled, and I'd mess up his other jobs as well.
Anyhow, I can see there are spots where they used too much water, or the exposure is not so great. I suspect that either that will get better or not. I can probably live with it in any case. I know that I can use a bit of wet/dry sandpaper to work on small spots and if there is any big deal, I can hire the plasterer to return with his underwater sanding equipment. I don't expect it to be perfect, hand crafted products rarely are. So expecting it to look like a Corian countertop is not realistic. But, I think it looks good overall. One problem area is clearly a different color, maybe stain leaking from the gunite they chipped all the way down to or stain from the flagstone steps adjacent to there, or simply a different lot of plaster. I note they were not trying to mix bags from different pallets at all and a few of the last bags were torn open and hardened. Anyhow, I cannot see that from the house or anywhere but from inside the pool, so I can ignore that.
