Just a side note: CH might matter in vinyl if it's too high, can get scaling if CSI is too far off.
yeah that is some low CA!!!
Nice job on knowing what did what while you were gone! You have this dialed in!
Kim
Too skinny to be yellow jackets at least the ones I have seen. Hummmmmm wonder what they are? Do they bite? The yellow makes me think yes.
Yup
Now if only I can find this best of suicidal yellow jackets, or whatever they are. 3rd basket filled with them in a week.
So, final results are:
FC remained at then shock level of 17.5 and fell to 16.5 when I just tested again
CC is 0
pH fell the expected amount of 7.7 down to 7.3 (tested after neutralizing chlorine with a drop of R-0007)
TA remained the same at 50
CYA climbed from 40 to 50 as expected
CH, didn't test cuz don't care about it with vinyl pool
I did top off the water with my well water, but have seen any signs of the full clear green tint of iron. Might get lucky though, since we'll should be full with no use in 4 days and only topped up 2 inches, so probably didn't disturb the clay and iron down there much.
