- Jun 22, 2017
- 861
- Vinyl
- CircuPool RJ-45
You need around 100 lbs of salt, so go ahead and get 4 40lb bags so you'll have some extra. Do you know what kind of salt to get?
Find a safe place to store the muriatic acid that is away from the chlorine. They do not play well together. The m. acid should not be stored by metal as the fumes can cause rust. I keep mine outside behind the barn where no critters go.
You put the CYA in the sock (the cuter the sock the better LOL) and hang it in front of the return making sure it does not touch the side. You can and should squeeze it to help the CYA dissolve. You can also put the sock with the CYA in it in the skimmer using care to not block too much of the water flow. If you do this you have to keep the pump running until it is all dissolved.
Kim![]()
Ok thanks! I got the pool set up today finally yay! But i still have to put up the filter and plan to fill it tomorrow. All your guys help has been so wonderful but i still feel so clueless! Can one of you just come to my house??
It is not dangerous to run swg and pump while we are in it?
So just to repeat back how I understood it (please correct me if i am wrong) I fill the pool with the CYa in a sock and then an hour before its full dump in the salt. Then when its full balance it like a bleach pool. Then can get in?? After 24 hours witg the pump running test salt and if ok then run SWG. Do i have this right?
@Kim yes i bought the test kit that was recommended on here! I believe lightmaster figured my pool to be around 4500 gallons. It was earlier in the thread but my internet is super sketchy right now so it will take me forever to go back to look but i think it was around there
Ok guys im up amd running with so much thanks to you. But.... I need some help with my chemicals (as we all knew i would). Here are my #'s
fc-13.5
cc. 5
ph-7.2
cya-30
Ch-225
alk-150
.... So i got a lil crazy with a bleach ...oops.. From what i read i just wait for the chlorine level to drop? Is that correct? What else should i add? I havent hooked up the SWG yet cos im afraid with the high chlorine level it would just make it higher?? At what point should i run that? Thanks again!
