I have a DE pool system. I need to replace the two hoses that connect the filter to the backflush valve. To do that I will need to drain the water in the filter. But, since I just disassembled and cleaned the grids, I would like to retain the new DE. My understanding is if I open the valve on top of the filter tank, the water will drain from the tank (back into the plumbing) and allow me to replace the two hoses on the inflow and outflow ports of the filter tank. My presumption here is the DE that has flowed back into the plumbing will be redeposited on the grids when I prime and restart the system.
Is this correct? Is there a better solution to my problem?
