I will be building a pool with a spa, a water feature and a Paramount in-floor cleaning system. I was told that Paramount prefers to have their system on a single pump. But I am confused about how this would work. The Paramount system uses a floor drain and a wall drain and a catch basket. So would you route the Paramount system s follows: Main drain >wall drain> basket>pump> filter>Paramount valve> Paramount return jets and then have a whole separate system: skimmers or spa drain >variable speed pump>filter> heater>chiller>chlorinator>returns and still a separate pump for the water feature. Just trying to figure out how the pros would do the plumbing. This will be my first time owning pool with an in-floor cleaner.
