I've seen some videos showing some particular solution, others talking about bleach, others acid... after rinsing off all of the goop, what's the best way to clean them?
Give it a good rinse first, make sure you rinse between the pleats. Then if you want to do more, then soak the filter in a TSP solution for a few hours.
Re: How to clean a cartridge filter After 7 years, I've replaced my 4 cartridges in my filter (I could have gone longer, but the straps were starting to break and I figured I had a good run with these cartridges). The replacement cartridges for my Jandy CL340 were from Unicel® and they had...
