I installed my first pool (Intex 18x9x52 XTR) about a month ago. I did my best to level the ground and the legs support using regular and laser levels. The pool is on compacted crushed granite covered with R-TECH panels and thick tarp. For leg support I used 4-inch thick concrete retaining wall blocks. I checked and rechecked using regular and laser laser levels and could not see anything wrong. Once I filled the pool, all was good except one corner that was about 1/2"-1" lower than the rest (just the corner, not the legs). I suspect it was probably because I did not expect the liner to reach that far, so maybe the base ground was a bit unleveled in the corner, but not 100% sure. I thought it would do for the first season, but today I noticed that the connecting rod that is close to the lower corner bent, the bottom of the leg shifted by about 1" and the corner went lowered by another 1/2"-1".
I rechecked the leg support blocks and they seem leveled:
The rod under the second leg also seems slightly bent, but not nearly as bad. Any ideas why this happened and what I should do short of draining the pool, redoing the corner and installing a new rod?
