+1 on the SLAM and below are the details.
To begin, do you have your own test kit that generated those numbers? If not, you will need one.
Also if your CYA is 70, your SLAM FC target is 28. Good job on raising the chlorine higher than most do, but as you can see it is not quite high enough to kill everything.
We’ve all had to deal with a green pool. Clear algae from your pool with a SLAM! Read here to use shock level and maintain to clear your pool.
www.troublefreepool.com
