Been weeks and I still can’t clear it up HELP!
+1 on the SLAM and below are the details.
To begin, do you have your own test kit that generated those numbers? If not, you will need one.
Also if your CYA is 70, your SLAM FC target is 28. Good job on raising the chlorine higher than most do, but as you can see it is not quite high enough to kill everything.
Should I lower the CYA then? I already have the test kit as recommended from this forum.
You need to raise the FC level to 28 - and MAINTAIN it there.
Test and dose FC at least 3 times daily. More at the beginning of the SLAM can be helpful.
Brush the entire pool daily.
Check ladders, lights, skimmers, weir doors, autofills for algae.
